Blower motors not working at all
Disco Mike
Have you checked the fuse? Relays are just circuit breakers and won't cause what you are describing, they only act up when there is an overly heavy power draw. My money is on a burned motor most likely caused from the build up of leaves making the fan motor over heat and fail.
thumb6plyr
Yes and replaced the fuse box with a new one. I cleaned out the leaves. Dealer found beverage spilled onto the becm. I have the old one. Now everything works. Just need to find the drains for the sunroof and clean them out....
thumb6plyr
Just got in my new driver door lock latch, Installed it and the door locking and unlocking has stopped. Was a fairly easy replacement. Took out the non-functioning cd changer and installed an amp there and put in 1 competition sub. Everything is Cool now.
