I would remove the switch cover for the windows and the pop the metal wire bracket that is wrapped in leather loose. At that point you slide the leather cover over the e-brake handle by pulling the boot over the handle while it is inside out.
If you have any questions, send me your number and I'll call you.
Are you installing a new boot with the wire bracket or trying to replace the leather, gluing the leather to the old wire bracket?
