MarcusTriton
I just got back from a 1000mi trip traveling in my luxurious 2012 LR4 and with the last 90miles to go, I fill up with gas, even though I had just a little over half a tank and then after about 10min. down the highway my CEL come on. I had no CEL on until just after the fill-up. Even with the CEL on the LR4 was operating just fine, so I pulled over and checked under the hood and underneath the chassis, just in case, and found nothing out of place. When I got home I hooked up my code reader and found Fault Codes PO172 and PO175.
What do you think is causing these codes...?(scan tool says "Oxygen Sensors Bank 1 and 2, detecting a rich condition")
What do you think it is...?
Oxygen Sensors...?
Dirty MAF...?
Vacuum leak...?
Dirty Fuel injectors...?
Fuel pressure delivery(P.S. - I did have the fuel tank flange replaced in January)...?
What should be the initial next step in diagnosing this problem...?
Thank you in advance for any insight into this dilemma...
Oxygen Sensors...?
Dirty MAF...?
Vacuum leak...?
