center brake lamp assembly replacement...
sdf6hr
forgive me if this has been discussed before and i missed it....
anyway, has anyone out there had to replace this assembly?
if so, any tips or warnings?
weekender do-able? or should the pros be brought in?
thank you for any feedback.
bbyer
Alberta
not a do it yourself
If you are a windshield glass installer, they you can do it. The same techniques apply. The plastic unit is glued in there just like a windscreen. Yes, it appears that LED's do not last quite as long as some think.
Below is link to my brake light switch album. Within is a wiring diagram that shows the electrical. Probably if your red tail light brake lights are working, there is power to the upper as well, but it may just be wiring problem.
http://www.**************/gallery/thumbnails.php?album=5082
Replace the ***** with disco3 co uk and put periods in the spaces - blocking and all that.
sdf6hr
sorry i did not give enough info and led you to think the lamp does not work...
the lamp lights perfectly fine when brakes are applied; my problem is the plastic lens has a crack / hole in it and i would like to replace it for appearance reasons...
i don't think it is an led set-up... i have an '08 se, all lamps on rear of truck appear to bulb fixtures.
thank you for the quick response though.
I think it is LED...the CENTER HIGH MOUNTED one I mean...but I haven't really looked.
PE_in_UAE
