Check Engine, DTC Codes and Diagnostic scanner for LR4
ragreene801
I've been using this one for years:
Carsoft Diagnostic Tool i930 compatible with Land Rover/Jaguar Vehicle OBDII Code Reader with Multi-Systems
I got it from amazon. I've been using it for years on my '06 and '12 3&4 respectively. It gets a bit more in-depth and i have had success resetting a bunch of stuff and avoiding the trip to the shop. On the other hand, it has been helpful when I get a code that tells me I need to take it to the shop and once I get there, having an idea of what is wrong helps me get the right work done faster (and cheaper). I have also had multiple battery issues that have caused quite a few codes. Good luck.
Cthehentz
Las Vegas
Have you tested the alternator?Check cold voltage and then start the vehicle and recheck to voltage, my R3 and R4 have both shown random codes with a bad alternator giving out fluctuating voltage.
00Jam
