Cigar Lighter Fuse Blown... I THINK!
E
elvispresley99
Recently, I believe I blew a fuse on my 2001 Disco II connected to the Cigarette Lighter port. I also lost the Electronic Compass, and the heated seats when this occurred. The problem I am having is that I bought the car 2nd hand, and I can't find a bloody manual for it anywhere in the states. I have pulled several of the fuses that are marked for AUX, and so on, but nothing seems to be bad. Does anyone have any suggestions, or perhaps knows what the correct position is for the fuse that may be the culprit on this?
Thanks in advance!
Elvis
D
disco1
The quickest way is to pull each fuse individually and visually inspect them. If they all seem ok, then continuity test them. The fuse that does not give you a reading is the blown one.
Jaak
Fuse #15 .. 20 AMP located under the steering wheel in the main fuse compartment.
Jaak Lepson
STQAddie91
