Crank/no start
Jhgrn3
Selden, N.Y.
Has anybody experienced a crank/no start problem after an extended repair with the battery out. I replaced the timing chains (alignment is good), water pump, crossover tube with new injector seals and some other miscellaneous parts. It was over a 4 week period because of parts availability and the battery was out of the vehicle for that time. It was not even attempting to start at first, now I am getting some attempt. I have read posts about all kinds of electrical issues when a battery is disconnected. Any thoughts?
jlglr4
Northern California
More info needed. When you first tried you say it was not even attempting - so, no clicking, no dash lights, nothing? Now what are you getting...dash lights and turning over, or just clicking or what? And what did you do to go from nothing to something?
Also, any codes showing?
djkaosone
'11 LR4 HSE LUX 5.0L V8
SoCal
Did you do the timing chains yourself?
I thought I did the timing was done correctly too, but it was off. I seriously ripped it apart 3x-4x. It's btdc vs tdc to set timing. I also checked compression and mine were all above 195 psi. It just cranks, but doesn't turn over. Here's my thread.
Post in thread 'Diy timing chain' https://www.landroverworld.org/threads/diy-timing-chain.31050/post-193224
Jhgrn3
Selden, N.Y.
Cranking fine just no fire. Now seems to be attempting to start but still not. No codes. Did the chains and double checked with the cam locks and the crank sensor pin.
Jhgrn3
Selden, N.Y.
Found the problem. The connection for the pigtail on the r/s fuel rail pressure sensor wasn’t seated properly. Took it apart, cleaned and reconnected. Starts fine now. Thanks for all the suggestions.
