crank sensor
widepud
the tac obviously is affected but the spedo does tend to go whacky at times but not always, also the spedo only goes crazy when the issue is happening. yes have tryed downshifting it happens in any gear. from dead stop and or if i shift down. but not in neutral or park.
If I were to guess since the speedometer it may be a bad VSS....
This can cause the issues you are talking about.
widepud
that could very well be it ill look into replalcing that next
widepud
where would be the ideal place to aquire a veicle speed sensor? every web site i try to do a search for it on comes up w no matching results.
SulliMtn
