cruise control -95disco 3.9
taxchecker
In tracing vacuum hose to the pump under the lf headlight, I discovered the pipe apparently broken off from the pump (because of uneven end did not appear to be cut) My question is how to replace the hose and hook it back to the pump. They hid it in a good place and I don't or can't even see where it slips on to the pump. Does the pump have to be removed to do this and if so how involved is it's removal? It's an awful tight fit and does it connect on the sides , top or bottom. It seems I saw this discussed somewhere before but I can't get back to it. Thanks in advance for your assistance.
Remove the jack, pull the pump out of the hole....
taxchecker
Thanks Joey, u made something that looked difficult real easy..already pulled it out and replaced the hose..haven't tried the cruise control yet..
PE_in_UAE
