daytime running lights
J
Jordan
Wondering if anyone can help? I've got a 99 disco2, I'm having a problem with the daytime running lights turning off intermitingly. I've checked for bad grounds, the switch at the transmision gear select seems to be ok, and the fuse is ok. Thanks for any help, I'm stumped
LRWheelman
Hello Cliff, Do your DRL's go out w/the parking brake? Could be a bad/dirty switch in there, but I'm just not sure. Thank You, LRW.
D
discomike
Your day time running lights are controlled thru the ECU, you may need to go have them reset with a text book.
Just a thought,
Mike J.
