Dead Passenger seat
ArmyRover
Went to move the seat today and found that it does not work. Checked the 30 amp and 5 amp fuse did not see any obvious issues.
When you hit the switch it sounds like a relay clicks but nothing cool happens, like moving. Anyone ran into this?
What else should I be checking
Ruper
Chesapeake, VA
I had a problem when I placed a new cushion in my lower seat but turns out I had not gotten the plug all the way in. I'm sure you already checked all the plugs so I am no help.
Possibly a ground issue, or the relay even if you here it activate it could have brunt contacts. Maybe switch out the relay for the same amp in the fuse box and see if its the relay?
remember5
Leave it to Landrover to have a 14 page overview of the seating system. Hopefully this might help.
  • Description and Operation.pdf
  • Front Seat Track Motor.pdf
MatttheHatt
US
I usually put dead passengers in the trunk...
Sent from my SM-G965U1 using Tapatalk
