Device error
Amygretchen
Just got 2011 LR4 for Christmas. I am bummed to find out though that the usb connection is giving me a device error. I am using an iPhone 6. Any thoughts? I need this connection to work or else a better Bluetooth option for streaming music.
Thanks for your advise and help!
AG
You need a proprietary interface cable to connect an iPod/iPhone to the 2010-11 infotainment system. Here is a video that may help:
https://www.youtube.com/watch?v=kaxZfoTxzYM
PS: If you have a recent iPhone (5 or newer), you will also need a male Apple Lightning to female 30-pin adapter, to make Land Rover's proprietary cable work with your device.
Annapolis, Maryland, USA
AG
I was never thrilled with the proprietary cable hookup in my 2011 LR4. The cable is short and stiff and it created an awkward storage situation in the cubby. Also, although I was fortunate that this special cable came with my vehicle, I have heard that it is fairly expensive to purchase. However, streaming my music was very important to me so I ultimately went with an aftermarket Bluetooth solution that has been fantastic. It seamlessly handles my phone calls and music. Search for "Kinivo BTC-450" in this forum for some threads where this was discussed.
I won't bother complaining about the fact that BT music streaming was not offered in the 2011 model (oops, I guess I just did). :biggrin:
Andy Ferrett
Brighton
For those that are interested I found a fix for this problem:
My iPhoneX was working fine with my 2010 Discovery, but when I reinstalled my phone it stopped working. After scratching my head for a few weeks, I found the problem was I didn't have any music setup in the Apple Music app. When the phone first connects to the car (through the cable, with adapter), it tries to play the first track in Apple Music. If there is nothing there it errors.
The fix was to add (through iTunes) an MP3 of silence (https://github.com/anars/blank-audio). When the phone is plugged into the car it plays the silence and works for all the other apps that require audio (eg Spotify, Google Maps, Audible etc).
I hope this helps.
Nikitaqwert
Usa
Thank you very much! It worked for my RR sport 2012 hse as well (ipod usb plug with iphone 12pro max) I was trying to figure out solution for hours, but always ended up with “device error” and such simple solution as installing Music app on iphone and sync 1 random mp3 song from laptop helped !
HuskerBred
Terre Haute, Indiana
What you need is an Invery bluetooth adapter. It plugs into the propriatory plug. Make sure you get the one for your LR4. My phone connects automatically now, every single time I get into the car. Works great and sounds real good. Found on amazon for about $75.
keithngwailok
Hong Kong
I hope this helps.
This solution is so underrated. It helps me a lot. I was figuring out how to solve the device error issue but only the simple solution.
Slytrellis
