Door Panel Removal
Ratcliff
Several days ago my driver side door handle stopped working from the inside. I knew that the cable had come off, but when I removed the door handle from the inside, I realized that I would need to remove the whole door panel and did not have time to get into that project. I took the car to the local dealer who told me that the process takes 1.5 hours and that the electrical connections had to be removed in a certain order.....making this a lot more complicated/lengthy process than I anticipated.
Is this really true, or is the process easier than that and I really should be able to do it myself?
Team Jeff
Supporting Member
Supporting Member
I haven't removed the panel myself, but while in the LR service dept. a few months back I watched a tech remove the drivers side panel in less than 10min. It's probably a matter of having the correct tools and knowing where the bolts/clips/screws are.
Hollywood619
I have removed the door panel in 10 minutes or less. Go to disco3.co.uk and search for door removal. It's easy and there isn't a electrical disconnect procedure.... more dealer lore to charge you more money.
