dsc inactive, air suspension inactive, and transmission fail safe program errors
jaylon
Few weeks ago I changed my rear pads, rotors and calipers and after about an hour on the road I get dsc inactive, air suspension inactive, and transmission fail safe program errors. I've tried turning the wheel from left to right and checking the fuses for the dsc with no result. I don't hear any leaks when the car is parked so I don't think it's an airbag. Anyone run into this problem?
Almost sounds like a battery going dead issue. When the battery drops below a certain voltage under load on a fully computerized vehicle all kinds of weird stuff will happen.
jaylon
I can try a battery, another thing I noticed but am not 100% sure wether it'd be related (but almost makes sense) is that the right front wheel started shaking pretty bad. I thought the rim needed to be balanced so I got it balanced, even got new tires and it got worse after changing the tires. At a low rate of speed, around 30mph, it's really bad; once the air suspension goes inactive it pretty much stops altogether. I'm pretty sure it's gotta be related. After sitting for an extended period of time the error resets.
Ok... with that info... I would say get that front end checked out....
jaylon
Ok, there was an issue with the suspension, changed the front lower control arms on both sides. The right side was pretty bad! Rides like a dream again, didn't realize how bad the ride was; I guess I got used to it. The error reset while I was working on the car, the shaking is completely gone and 'maybe' 5 minutes into my test drive to see if the error would be resolved *ding* that awful sound reared it's ugly head again. So now I just don't have a clue as to what it could be, I checked the battery using a meter and it's 12v off and 13.4v running. Any ideas .... .... .... ?
You never mentioned your model / model year. On a RRS / LR3 and LR4 - probably a Range Rover as well - cascading errors like those (when you are already up and running) are often caused by a bad brake light switch, or even an installed brake light bulb of the wrong type/rating. This is especially true if all faults seem to pop up after you press the brake pedal.
mishgass
DSC and Air Sus Inactive
Hello all, i am having this error now for a couple of days they both pop up the same time along with the ABS light. my RR is 2003 classic model. looked around online and found several things to do like unplugging both fuses clean and to reset and steering lock. it works but i get it again after a while. also some mentioned to change the battery, not sure of that but am welling to try.
any other suggestions to this fault?
