DTC P0741 Lock-up clutch monitoring.
ngv151515
my 2001 Disco2 is not running well sometimes it wont go on gear and it only has one code wich is DTC P0741 torque convertor Lock-up clutch monitoring solenoid stuck open or close. does anyone had the same problem before? i cant find the part number for the solenoid to replace it. car has clean transmision fluid its been service before. the level is correct too. i really need help this time any ideas?
Sorry, I was out or didn't see this post., how old is your battery? Sounds odd, but a bad battery or charging system will cause transmission issues.
Check the voltage, should be between 13.6 and 14.4.
Try driving it in sport mode, does it make any difference?
MrRodgers
