EVAP Issues
Ernie O
I'm having an issue with an electrical valve, called EVA or EVPA valve. I'm not sure what it's called, but the computer is saying it needs to be changed but I can't even find one to order. What is the name of this valve and where can I find one.?
Ernie O, more info needed.... does this have to do with the air suspension?
Or are you talking an EVAP item which doesn't involve the suspension?
Ernie O
This has nothing to do with the air suspension, I think. The valve is located under the hood. But I don't know what it is called, or where I can get one. I went to my mechanic and he said that is why my engine light is on. He said it is a EVAP pr EVA valve. I'm not sure, i couldn't understand him.
Ok, so I don't have to go back in time... first I Opened this under a new topic, since it has nothing to do with Air Suspension.
Second... Do you have a D2 or D1?
Ernie O
Oh, I'm not really sure how to use this forum. I'm Ernie's son, August.
I have a D2.
Ok, the part you are looking for is not cheap... you have 2 of them. One on each side of the engine. Kind of hard to describe...
Do me a favor take a picture of you engine bay from the drivers and passengers side and I will point out the EVAP valves... the sad thing is, unless your mechanic is a true rover mechanic he may have no idea what he is doing other then reading the codes... could be a simple fix of an expensive parts replacement.
SulliMtn
