Flat tire and suspension fault
wayoutwest
Newbie here. Had an interesting situation last night that continues to linger this morning. Any help on the matter is greatly appreciated.
So, driving back home on I-70 tonight and nearly got home, but heard and felt a huge bang/pop about 10 miles from home. At first, I thought I simply hit something bouncing on the road, based on the sound and the fact that I could actually feel it. However, about 5 miles later I got a red suspension fault just as I was getting of the interstate to check the problem. So, pulled the car into a lot, and the tire was blown. Didn't think too much of it, thinking that the sudden drop in pressure (driver's side rear) probably triggered the suspension fault. I swapped out the tire for another full size spare I carry in the back (I run 285/60/18's). When I got back in the car and started up, I figured the fault would disappear and the car would operate normally. Unfortunately, the fault stayed. So I limped home on the red suspension fault, limited to under 30 MPH. Once home, I performed a hard reset, thinking that would likely clear the fault; unfortunately, it didn't. So, at this point, I'm a bit confused as to what may have happened and how to resolve the issue; any insight is greatly appreciated.
Some info:
It's an '06 LR3 SE running 285/60/18's with J Rods.
I performed a hard rest; no help.
When I changed the tire, I DID NOT jack on the compressor.
I did check the compressor casing for any signs of damage, but nothing appears that I can see. I have never had any suspension faults on this vehicle, except for one time when I installed the J Rods and got some grease on the height sensor.
The blown tire was driver's side, rear. I can see the puncture hole, but whatever caused it (guessing screw/nail) is no longer there. Not sure if it was initially stuck in the wheel & centrifugal force dislodged it, or maybe it simply punctured the tire and never actually embedded in the tire.f
So, any ideas?
