fuel pump
USMC3051
hi everyone new to this forum, a little about my vehicle, have a 2004 range rover 4.4 hse, 91k on it. i just changed all four brakes last night, this morning i went for a drive and the truck shut off, just died, electrics work, it wants to kick over but won't I'm thinking its the fuel pump, my question is if i spray starter fluid into the intake will it mess up the MAF(Mass Air Flow sensor), also when the key is turned over the battery indicator is on(red) could this be an alternator issue tried to give it a jump but to no avail, any advice will help trying to avoid the 900$ fuel pump from land rover, thank you.
USMC3051
does anyone know if its possible to use a BMW X5 4.4 fuel pump, seeing as the engine, tranny, and chasy and just about everything else is BMW?
Wish I could help, sadly I don't know much about the newer Range Rovers... Give Nathan a call in my signature I am sure he is familiar.
USMC3051
thanks for the info found a pump online just the pump for 140$ its installed and works just having starting problems now bout to recheck the orings make sure the seal is good so there isn't any bleed back.
PE_in_UAE
