Hi all,
My 2011 LR4 has been giving some grief in terms of cabin heat. It blows real nice and hot when above 1200 rpm but below that, specifically at idle, it blows ambient temp. I've tried the flushing method with setting up a circulation pump and pushing clr and hot water back and forth through the core, but it didn't do solve it. The drivers side is the main trouble area as well as the rear heat.
Any guidance on how to access the front heater core? I am having trouble pulling that trim piece on the middle console where it hides behind. Also, will swapping this core out help the rear heat as well?
Located in western Canada so low heat is a real no go, although the heated seats go a long way.
Thanks
Thanks
