Hella 4000 Install
M
MToomey
Ok group, I forgot to pay attention in highschool during the science class that dealt with electrics and so forth...
And I apologize if this has been addressed (but I searched)...
How does a layman install a pair of Hellas?
I got the correct wiring harness, I got the directions, and I even got the lights...but what now?
If anyone has done this before they might agree the directions leave a little to be desired.
Specifically my questions/issues are:
Where am I "supposed" to mount the little blue fuse box?
What are the extra wires on the harness that attaches to light for(I think it is a gray one with a little connector on it)? And what do I do with them?
How does the green wire come into play?
How do I utilize my factory fog light switch once install is complete?
I understand the following:
Red is hot, brown is ground, and blue connects to the actual light via the harness. And it seems (seems is a strong word here), the yellow wire gets cut out completely.
I'm not doing a thing until I hear a strong reply, or 24 hours, in that case, I'm taking it in.
As always, thanks in advance for your help!
I haven't done the hella install, but you should have a hot/ground/light wire, and a relay wire.
the relay will be the one you connect to your fog lights. It basically activates the realy and then the hot wire will turn on the lights.
also try this link http://204.157.1.3/lights/
Mavsdad
