Help please!!
Jodaaleman27
Hi everyone!! I recently bought a 2005 land rover lr3 v8 and everything was good until I drove for 15 minutes and then lights start appearing!! Brake light and then a dsc light and the hdc fault and the suspencion lowering and the special system off i a ready change the batterie and still the same please healp!!!
PaulLR3
Boston
I would start with the brake switch. That can cause the "Christmas Tree of Death" you are seeing. It's about $50 from the dealer and very easy to install yourself. Atlantic British also sells the OE part and this aftermarket one:
http://www.roverparts.com/Parts/XKB500110
There is also a video at this link on how to change the part.
PaulLR3
Boston
Well, the symptoms you described matched the brake switch failure exactly. That would have been the inexpensive problem to fix.
Next step is to take your LR3 to a dealer or a good indy mechanic with LR experience to pull some codes.
Mx468
Any of your rear brake light out? Do you have a code reader?
Jodaaleman27
No but I recently changed the bulbs and I got a code reader but doesn't show up any code and I check the battery and it looks like it's not the recommended for the truck so i going to replace it tomorrow and see what happens
Mx468
When you replaced the rear brake light bulbs, did you use oems? If you used aftermarkets, than there is your possible problem. Its weird but the LR3's are real finicky about using aftermarket brake bulbs and will throw all sorts of suspension, dsc, etc faults.
Sid1577
