Jack Pads
Fm540i
The stock jack on the LR4 may be fine for emergency use but scissor jacks are a pain for basic garage work. I'd like to use a heavy duty rolling floor jack but the frame lifting points are difficult to lock into without using some type of jack pad that fits the indent hole used by the stock jack. What are others using? Any source for a proper fitting jack pad? Or perhaps using an alternate lift point
Thanks for your help. Hoping to make switching over to snows easier. My first attempt already cost me $75 when the jack damaged the air suspension pump cover!
CMGRover
I just use the normal jack pad in the normal places on the frame...no issues.
PE_in_UAE
