Leak on top of engine
Cedricmjohnson
Engine Cooling problem
2001 Land Rover Discovery 2 V8 Four Wheel Drive Automatic 90K miles
I have a leak on the top. I use stop leak with dye and the leak is showing up, I need to know what the name of the part that's leaking, its connected to the part that's connected to air filter but underneath the part that is connected to the air filter.
I couldn't get a close up picture
Man I need help, my warranty may not cover it and I will have to pay the diagnostic charge, which seems more expensive than the actual part.
Hey we in a recession, HELP? :frown:
it is the deicer assymbly. about an hours work to fix for someone who has never done it before... easy... fix...
Where are you located?
Cedricmjohnson
Joey, Thanks man. I got a reply from Braddy's British Motor Works he says its the throttle housing connected to the inlet hose and return pipe.
I can send you a picture with me pointing to the area if you send me your email.
I really appreciate your help.
Cedric
314-653-8932
I already know that is the correct part. not hard to change.
