Lost The Wire
M
MightyMax
So i went to check why my door pin on my drivers side wasn't working...so i unscrewed it and found the wire connected to the pin broke off and is somewhere in that front door panel. Any ideas on how to get in there and grab it?
I presume you mean the wire for the light switch at the door (dome light). If that is the case, you can try to get there from the inside of the vehicle (not sure if this can be done, or make sure you disconnect the battery and get a small wire and make a hook and feel around for it...
M
MightyMax
tried that already...had no luck. Do you know of any other way of getting in there?
I will take a look tomorrow and see if I can figure something out for you. Of course I will not spend a long time as it is below zero outside.
Thought I would let you know, I Look around and without removing the dash I can't see how your are going to get to that wire.... I know my hands were not small enough.
tragic1
