Low speed metal on metal noise?
D
ducati2349
Lately on my Disco2/64k at low speeds there seems to be a slight metal on metal noise coming from the left side that goes away when I apply the breaks. Any thoughts? I know that the rear diff. fluid hasn't been checked in awhile due to the plug that no grease monkey has the correct tool to take off. Is oil level really the cause of my noise?
Frustrated in Seattle.
Jeff Discos
Left front, left rear, speed hearing noise at, during acceleration/coasting, brakes looked at? etc...
The diff plug can be taken off using the 1/2" ratchet if I remember correctly. Every grease monkey has one of those!
if the sound goes away when you put on the breaks, check to make sure the brakes do not need replaced. That would be my first thought.
D
ducati2349
Yep the brakes was the problem. Good to go now, just need to fix the cargo door and passenger door from unlocking...stupid locking unit device thing.
