LR2 transmission fill and check
Procore
Sarasota florida
hello, writing here because can’t find info that’s correct it seems as to 08 LR2 transmission fill and check so offering up what I figured out
To check level:
Jack up and support with stand and wheel ***** and remove front drivers tire
Remove plastic inner wheel tube over
To right side of trans case you will see a plug facing up at a 45 degree angle that’s the check
Fluid location needs a T55 to remove
As for fill:
Remove air filter box don’t remove MAF sensor attached to top just set a side. Bottom just
Pulls up and out. You will see same kind of plug that needs T55 to remove. Use a knuckle ...Fitting on you racket wrench with extensions.
I read a lot of posts from different places not very helpful this worked easy for me
