LR3 Halogen to LR3 Xenon
tomasesto
trynian
Yes Tomas, I did it right after I got it. Easy plug and play change. Don't bother with the aftermarket kits. In the end you will be happier with the factory.
I usually see the halogens on ebay for around $150 but probably $100 each would be fair.
Did you see my new winch install?
http://scottsroving.shutterfly.com/
Im about to try and clean the inside lens part that requires heating it for removal and its got me a lil haired out! Just dont wanna melt or warp anything ..Any Tips?
Trynian
I have never taken them apart.
motz
I did it on my Scion and it was pretty easy. Make sure you don't put it too close to the heat
And make sure to seal it goodd when u put it back. Mine wasn't shut good it started to
Sweat inside and I had to reglue again.
motz
Did you try asking ur local shop or maybe read ur Extended waranty to see if thats covered?
Mine is not HID, just regular headlight. I just want to upgrade.
I found a good pair online but it was the adaptive one.
As long as it works as headlight, im okay ( i read adaptive function dosnt work).
But i dont want to order if it deosnt even work as headlight, or it doesnt work right.
tomasesto
Ive read that the headlight works fine w/o adaptive function but Im not sure by experience so I decided not to spend the extra and found some Non Adaptives to switch too. Make sure to give whatever u purchase a really close look for inside sweat marks etc cuz the shadow at nite gets annoying :driver:
MArsel
