LR3 Tow Hook
flysurfer
Quick question. Does LR3 come with front or/and rear tow hook(s)? I don't see any on mine and accessories don't show that option either. How can LR3 be rescued without it (say, from mud)? Thanks - Brian
duckdive
There are recovery loops behind removable panels on both front and back. The front
one is behind plastic skid plate removed with flat head screwdriver. The rear is above
the receptacle for the tow hitch, also removable with flat head screwdriver. Check your
owners manual Im pretty sure it's in there.
davez26
Both are hidden
In the front, there is a lower flat plastic panel which is easily removed w/ 7? retainers. The tow hook lives under there.
In the back, the tow hook is in the center bumper face behind a plastic panel held on w/ two retainers.
Both are very sturdy. The manual reccommends to remove both covers prior to going off-road. In mud, I'd especially go for that, because those seven retinaers would be hard to find under goop.
On the other hand, if you use it a lot off road, you just leave it off, or I opened up a space in the front of the panel that you can use to put a quick d-ring or hook without removing the panrl.
flysurfer
ah~~~ I see. Thank you guys! I will look them up tonight. - Brian
helge
