LR4 Interior LED Lights
Got my kit... BRIGHT AF!
But very nice color temp. Easy install.
I need to plug in the IID and see what it thinks the amp pull is now. I bet it is a lot less. Those old bulbs get way hot.
And I should mention, that is only the center dome lights, there are 4 more that aren't even on
Did I not warn you!?
I hope you like them. Setup looks awesome.
If you wanted bright, you got bright...
How hard is it to take out the middle seat?
I like the brightness. And yes you did warn me. Will be fantastic for camping. I am also just interested in lower power draw.
Taking out the middle seat is quite easy, just make sure you have the correct bit for those bolts. No wires or anything for the middle seats.
LR4USN
I would like to see a pic with the middle seat removed. That's an awesome idea !!
Easy to take out. I put in tie down brackets where the bolts were for securing things. Most coolers and an ARB 50QT fridge will fit there perfectly.
You can also access a little bit of space under the third row seats. I store recovery gear (VIAR 450p, shackles, tow strap, extra tie down gear for roof rack, etc).
Notice how well lit this sh*t is... LOL.... that is in my dark garage with no garage lights on.
BaroloBlackLR4
LaGrange, Georgia
When I just added the 16-piece Full Upgrade kit, it rings up to £111.00 (143.86 USD). Is that what y'all paid, for real?? I mean the results are insane. But, is it worth $150 for the full upgrade?
backcountryLR4
Utah Backcountry
If you want bright AF, then that is probably right...
If you just want the nice looks from LEDs(that are plenty bright...), you can get cheap replacement bulbs for all locations minus the front door puddle lights.
The 2 frond door card lights were £25, but the only thing that would work.
That full kit is bright enough to perform an operation in pitch black.
Depends on what you want. I'm happy with my setup for ~$57 with a few bulbs to spare.
Ya, $138, the exchange rate was a little better then, but I am willing to spend a little more for the simplicity of a complete kit that I know is good quality stuff. I am sure the other options could be fine also.. but I don't know.
Still really happy with the kit. They stay cool, and its been nice for camping. They don't draw much power which was the main thing I wanted. I haven't felt they have been too bright. (but i did find the stock ones to be dim sometimes) Strangely I haven't noticed them drawing in the bugs as much as I thought it might. I figured bright white would attract bugs.
