bertram7
My '11 LR4 had a sunroof drain issue that left the passenger carpet and underpadding damp. I've run a dehumidifier in the car for about 10 straight days to pull the moisture and that's helped but now I've got the below faults
- ABS fault
- Stability control not available
- Emergency brake assist not available
- HDC not available
- Parking brake fault
- Ride height lowered
I've disconnected the neg terminal and done a reset (touching both) but the faults remain. I'm assuming the moisture messed with the myriad electrical connections in the passenger footwell/under floor area. Any ideas where I should target before I start checking all the connections?
Thanks in advance
- ABS fault
- HDC not available
Thanks in advance
