Maf Sensors...
ugmw177
Charlotte NC
son advised me CEL illuminated and tripped p0101 again after several months of not doing it. Have cleaned the MAF sensors twice and replaced the air filters. checked the wiring etc. so guess i will drop the $$ for some new maf sensors. I see LR, Denso [i think oem LR], Bosch and a myriad of el cheapo chinawese stuff. Will probably go with the Densos but thought i would ask here what others have used successfully
jlglr4
Northern California
FCPeuro lists Bosch as the original equipment, for whatever that’s worth. I haven’t had to replace mine, but I seem to recall that others on here have reported using Bosch as well.
ugmw177
Charlotte NC
Thanksk, i like bosch stuff; usually reliable. Seems to me that Denso is the oem for these. I will probably give the bosch a try
itsaguything
Manotick, On, Canada
P0101-00 is Sensor A. Are you certain it is securely attached and clean.
Also, what did you replace the air filters with? And, are they matched?
ugmw177
Charlotte NC
It is securely attached. i cleaned them both several times with MAF cleaner. Replaced both air filters with oe Land rover paper filters. Did clean out a few dirt dauber nests in the housings...it did not set cel for a couple of thousand miles but now triggered it again as p0101.
PE_in_UAE
