Motorized Antenna Mount
mhb907
Has anyone had experience with motorized ham radio antenna mounts? The two mounts that I am looking at are the Diamond K900LR MO and the Comet MK-30H. They both rotate a mobile antenna between horizontal and vertical (90 degrees).
Lando Man
I've just bought the Maldol, primarily on looks. It does have a vertical case split, so it may have a water ingress issue as time progresses. I'm having a welder fab two AL plates which will span the roof rails to support 4 V/U tilt ups (on motor mounts) and a detachable DF array. Eventually, HF will be a High Sierrra on the front bumper, mounted on a custom fabbed bracket as well. ...........Reed
