New Compressor Design/ Suspension Fault
F
flowner
A couple of days ago I had another suspension fault this time with the newly redesigned compressor. The fault went away after the car was restarted and has not come back since. To test the compressor I raised and lowered the vehicle several times but no return of the fault. This time I think it's proablably a sensor going bad. I know a couple of people had faults due to exposed ride hide sensors. Does any one know how to check the sensor.
racingdc9
Same here. this weekend, I got 2 Suspension Faults, and haven't happened since. Yes, new compressor.
F
flowner
Just got another tonight. I turned off and Restarted and its gone again
N
newenglandlr3
Oh fun! Whats the time from the swap to the first fault?
askewed
I think it's worth sharing that the suspension fault is how I got a replacement truck. Check your local lemon law. LR doesn't want lemons, they'll swap the truck to avoid giving you the truck back after the third compressor goes in...
Start a file with LR CSR, mention EVERY problem the truck has had. Be clear your not trying to make a problem... Just want to avoid the L.L. process. Good luck!
F
flowner
Thanks for your help.
In Florida you have to notify the manufacurer, which we have already done. If we want to do lemom, our next step is to file a claim with the state. I agree I think it would be to our benifit to point this out to them.
A few questions:
What did you do with your vehicle once you started the process.
Did you leave it with them and did they provided you a loaner in the meantime. How long did it take them to react.
Who did the transactions for the swap the dealer or Land Rover.
racingdc9
I think mine was around 1.5-2 months after new one installed
Flowner: I think it's just a matter of time, might as well call your dealer now. I'm gonna call next week, once things settle down(Houston-Hurricane)
L
LastRoverForMe
I received my LR3 back from the dealer last Thursday c/w with a new air compressor and the ride is awful. I took it back to the dealer in Oakville but they cannot locate a problem...computer says everything is OK. Unfortunately, this is not the case as the vehicle completely bottoms out over even the most minor road bumps. I wish I had my old compressor back beacuse the LR# rode life a limo now it feels like a tank..thud thud thud etc.. Has anyone else experienced this problem after a new compressor installation?
helge
