Noise from maybe the front right.
Turley
ROXBORO
So there is a cv joint noise... doesn’t sound the same. It is intermittent, doesn’t get worse with turning the wheel. Sounds almost like something is taping, I pulled the wheel off, changed the rotors and brakes on both sides. Nothing feels loose, looks cracked or anything of the sort. Anyone else run into this before? 2010 LR4
Depending on Mileage you may have a hub bearing going bad. Less than $60 IIRC.
Turley
ROXBORO
I grabbed one off rock auto the other day, but haven’t been home long enough to take it off.
Rotors, brakes, plugs, coolant cross over tube. Then this mystery..... Not to bad for 140k
NASdiesel
I recently ran into a failed air bag on the front right corner that started out sounding like a tapping noise over bumps and quickly became far worse as it progressively failed. Less than year old Bilstein $$$. Returned to using OEM parts. Eventually as it progressed, threw a compressor fault.
