Nudge bar update
land crzy
OK so I have convinced wife to accept the OEM wrap around nudge bar.
Is the install complicated? Does the bumper need to come off?
Any fellow members with photos?
davez26
Instructions @ ownerinfo.landrover.com.
Difficulty is based upon ability.
Sorry so short. meeting going to.
GrahamWelland
Are you looking at the tubular steel bars or the plastic A bar?
I originally had the boxy bar - it requires drilling through and mounting against the front bumper so some limited body work is required. I changed to the tubular front end with winch and that leaves the bumper intact (I had to get another one since my other one was drilled through!) and everything mounts underneath and on to the frame.
BazLR3
Where do you find the exact location on the bumper to drill the holes for the tubular frame? In the installation manual it just says 70mm without indicating how far from the ridge it should be (if you have the instructions handy you'll know what I mean).
PE_in_UAE
