O2 Sensor #1
elvis
check engine light came on - bad O2 sensors
i replace all 4 and the front ones are not working
what am i missing? i pulled them and put a torch to them and they tested good.
i am trying to find a wiring diagram to check if i have a short.
any thoughts?
Disco Mike
Always give the fault code numbers if you want help since there are at least 16 just for the 02's.
Did you clean you electrical connection before reinstalling them?
Disco Mike
That code is only for B1/sensor 1 and does not include bank 3.
That being said, you will need to replace both front sensors to keep your air/fuel mixture the same for both banks.
Is this something you are planning to do yourself?
elvis
I have replaced them and they do not work. I am unable to figure out the issue. I replaced all 4 and with the use of a buddy's computer, they do not have a voltage flux like the rear ones. I was thinking a fuse, but they don't have one? And then maybe a short but I can't find where they would plug into the emission control.
Thank you
Disco Mike
Not a fuse issue. When you installed the new 02's, did you remember to clean all the grease and oil out of the electrical connection, if not, that can be your issue.
Paul p
