I need some advice pertaining to the oil pressure sending unit.
I own a 1996 Disco and the oil light comes on only when Ideling and the AC is
turned on. If I turn off the AC the oil light goes out. Also, this problem only occurs when the engine is ideling in gear (auto trans.) or in park. Seems like the oil sending unit may be bad or a bad connection. What do you think ?
Where are the plug connectiors located for the sending unit ? Also, could my serpintine belt be loose ? I found the temp senor connector near the water pump. I know the oil sensor connection is on the timing cover. But where is the timing cover ? Whic accessory is it near or is the timing cover on the rear of the engine near the firewall?
Also, where is the Oil Logic unit or computer located ? I'd like to clean the connections and check the wires for breaks and us a multimeter to test. If the problem does not go away then I'll unplug the unit till I replace the oil logic unit. Hopefully a good cleaning will resolve my issue. The flashing light bugs the devil out of me.
Thank you.
Thank you.
