P0089-64 (E8) Fuel Pressure Regulator Performance
EdwardRRS
Hollywood, Florida
Hi,
2016 Range Rover Sport Supercharged -85K miles- Out of Warranty.
Code using an IIDTool BT
P0089-64 (E8) Fuel Pressure Regulator Performance- Algorithm based failure-Signal Plausibility Failure.
Search on the Internet mentioned.
Might need to Update the PCM Software..How does one do that?
A Part might be bad. Which Part is bad?
Fuel Pump? Low Pressure or High Pressure Pump?
Sensor or Sensors?
Regulator?
Any software updates with require either the dealership or a Land Rover Specific mechanic as they will need that lovely $10k computer to install the update.
Not sure what the error ends up being.
EdwardRRS
Hollywood, Florida
The Check Engine Light disappeared for a day and a half and returned today. I overfilled the tank and it went away. When I hit 75%, the Check Engine Light reappears.
