power steering fluild
Depending on the year LR mostly uses Transmission Fluid.
bolha79
04 dicso with power steering fluid max life is this ok?
Disco Mike
All D1's, classics and Defenders ran atf, D2's us power steering fluid.
Yes, Max-Life is fine.
hi_arshard
Power steering fluid
Is it ok to use transmission fluid for power steering ? on a disco1 year 95 ????
Maddie
Yes ATF is fine in a 95 and is recommended.
Va_Disco
When I bought my current Disco about 1 year ago there was a bottle of power steering fluid in the back. I never paid it any mind till I checked the fluid the other day and it is clear. If the previous owner used power steering fluid should I worry? Should I drain the system and refill with ATF?
No Worries Va Disco, keep in mind there isn't much difference between power steering and Transmission fluids (there is a difference, just not much other than cost)
