Heated seats
I found the plugs in my 2000 series two. Like was stated you have to pry off the top cover (mine was black pastic) on the center console. Be carefull because the reatining spikes are pretty flimsy and break easily. Then I has to remove the four corner screws and dig around a little bit. You should find two plugs one black and one green. They are not very big, maybe 1 inch by 1/2 inch. One is right and one is left. I can't remember which is which. If you have them you got heat. The other less invasive way to check is just look under your seats. From the back seat floor look under the seats and you can see the heating wires that go into the back and bottom pad. I bought my switches off e-bay for like 20.00. You need the plates with the right cut-outs as well.
