Rear diff is damp
CMG: There is no way that any of us can really give you an intelligent answer. You have observed it first-hand and if you are asking us, over the internet no less....I don't think that any of our answers can be anything more than speculative.
Take it in...
CMGRover
Closest dealer is 2.5 hours away.
Guess it might be a good time to try the shop that always has Land Rovers on the lot...seems to be the only place in town that knows them.
tlt
I suggest 2 each TZB500050 OEM LR side shaft seals. At a minimum, drain the fluid, capture it and inspect for rust. If you have rust, water or metal shavings then you should remove it and have it rebuilt as well as the seals. The fluid should be changed every 25k miles. You can order the seals or rebuild kit from lucky8llc.com.
Johnathon65846
