REAR DIFFERENTIAL PROBLEM
djatkinson
My '06 LR3 HSE is throwing codes that my indie shop doesn't want to touch.
They read as such:
REAR DIFFERENTIAL CONTROL MODULE
2 faults present
P0900-00 Clutch actuator-circuit/open
P080A-00 Clutch position is not learnt
Does anyone have any idea what I'm about to get into here?
Dan
Dan, do you have the HD Package? (i.e., locking rear diff and full-sized spare)....if so, I think I know what's up.
djatkinson
Houm_WA,
Good to hear from you!
I do have the locking rear diff and full-sized spare, if that's the HD package. I was thinking that was part of the HSE package!
Anyway, if you have any ideas, I'm open!
Dan
I was getting that same fault, even RIGHT AFTER replacing the rear diff. The cause is the locking motor/actuator that sits on top of the pumpkin. Replace that, program as necessary, and you are good to go. If you haven't changed the fluid in the rear diff in a while, that'd probably be a good idea, too.
djatkinson
OK, sounds like a great plan!
Now, what is the part and/or number??
How do I program it???
Hahaha....well, I don't know that stuff off the top of my head. I'd find out the same way you would, either internet or call my Dealer Parts Dept....I'm sure I have it on a printed invoice somewhere but finding that would take longer. As for the programming, if any is required, I don't really know. I didn't do it myself.
djatkinson
Houm_WA,
I just got a little info today from another shop that specializes in Rovers. They have a good reputation from the local N TX Rover club. I just haven't worked with them before. They will tackle this project. The owner told me that actuator and the motor involved in making the locker work, are a combined set; you don't replace one without the other, if I understand it right.
They would scan the whole system first, to make sure there are no systems interfering with this one, or vice versa; then check for loose wires, bad connections, etc.
If there are no complications, the bill for the job is $1120. There is some programming involved in making the actuator/motor work.
One thing's for sure--we're not driving Jeeps!!!
That sounds WAY too expensive, even for a Land Rover. The part is a couple hundred bucks if I recall correctly and the labor for the R&R shouldn't be more than an hour, maybe two. Should be about half of that bill. I had mine replaced at the dealer, and I didn't pay anywhere near that.
djatkinson
Well, I looked up the parts on LandRoverParts.com. The actuator was around $157 and the motor was around $450.
He sounded like it was not the most fun or frequent thing that he does! :(
I can't remember if I changed both or just one. I can go dig up my invoice if you think it would help you. My only suggestion though, is that you get a second quote, even if it's from your local dealer service department. The labor cost sounds high.
STQAddie91
