Rear door vent glass vs window glass replacement
SoCalAnt
Orange County, CA
Hello all,
Because of the fact that my keys are sitting on the rear cargo mat in plain sight with the vehicle locked, I've got a decision to make. It looks like I have no choice but to break one of the windows. There are a handful of L322s at the local yards, so I have replacement glass available.
What glass is less labor intensive to replace? The main door glass or the smaller vent window glass? The vent glass I guess is glued/bonded from what I've read. I've seen plenty of door glass replacement videos, but I can't find any information on replacing the vent glass, so I don't know what's involved.
Which one is getting broken?
Rover Range
Texas
Neither one.
You can remove the rear license plate light assembly.
Use a screwdriver to gently pry the sheet metal apart.
Use some needle nose pliers to pull on the rear hatch safety release strap.
SoCalAnt
Orange County, CA
I called AAA and after two different people tried, a third guy came out and successfully picked the door lock.
I was moments away from just saying forget it break the window.
tragic1
