Roof drain pics
GeoRover
Anyone has roof drain pics? I am trying to figure out a problem in my LR3. Driver side wet floor and now noticed dampness on front headliner near the map lights. I know its a comon problem and is usually related to clogged drains. Wanted to fix it myself and see what kind of info I can get to solve this issue?
GeoRover
I found them at:
http :// disco 3.co.uk / forum / topic22757.html
(Remove spaces to get to the link) Apparently sharing knowledge across forums is a crime ;(
NOTE:
In future if you want to add links to "banned" forums or sites from here, just go to http://bit.ly ; shorten the URL and copy/paste it here like below:
http://bit.ly/z61QGw
This link goes to the same forum I listed above.
milan281
Does any body have a list of odb codes for a 2000 and 2003 Land Rover Disco
roverlen
Drains are in each front corner of tray(laterally towards doors). Look down with roof open and stick a sizeable wire the length from roof to ground into hole to poke debris out. The bottom of drain is behind plastic inner fender and you should hear it poking plastic when you bottom out. Pour water gently in trough to see if drains are clear both side.
