Rover Down
bjanssen1174
hello hope you can help
3/28 1:00am with two small girls (1 &3) I was driving my 2003 Discovery (62000miles) on the highway last night and my check engine soon light came on about 30sec later the engine shut down. After about 30mins the car started up and everything seem just find despite the light still being on. I had the truck towed home ($170). I pulled the ODBII codes this morning. Can anyone help me on where to get started. I cleared the error and none have returned and everything seem to be running great. All fuild level seem fine. It was real cold last night when failure happen (15 deg). Can someone please help me.I got 6 codes as follows. Thanks
P1300 Land Rover Catalyst damaging misfire multiple cylinders Drive cycle C:Signal out of range - above maximum
P0335 Generic Crankshaft Position Sensor A Circuit
P0304 Generic Cylinder 4 Misfire Detected
P0307 Generic Cylinder 7 Misfire Detected
P1884 Land Rover CAN message WFPDK (DKI) invalid (FFh).
P0300 Generic Random Misfire Detected
3/28 9:00pmMy Disco just died again and this time it will not start. Parked on the side of the road. This has been a bad day. I will have it towed home tomorrow. Any help would be greatly appreciated. I understand the codes but just decrypt want to do first. I have checked all wire connections (Crankshaft position sensor. Spark plug wires have only 2k on them. Thanks
If you have already changed the Crankshaft Position sensor and you are still getting these error.... hmmm I know without the P0335 I would say Plugs/Wires, or MAF sensor... you have already changed the plugs and wires.
What plugs did you install?
