Seafoam back again.
AlexDisco
Sorry to bring it back up. I read through the posts but the pictures are not there for the D1. Is the vacuum line going from the passenger side valve cover (PCV valve) the right hose to put the seafoam into? Also I located one hose on the intake manifold will this one work. Which one is better?
1995 D1
N8tabasco
If you are looking at your engine from the front, you will see this hose/tube. Pull it out of the top of the rocker cover (I think thats what its called) and rotate it upwards so you can pour the seafoam in. This is on the drivers side.
AlexDisco
Thanks for the pic. I did see this one before but my engine (3.9) is slightly different. I used Seafoam deep creep and although my engine did not smoke as much as others I read about, it sure feels stronger.
Thanks,
Alex
