Service Engine Soon Light
brizhome
Does anyone know where I can find the Emissions Maintenance Reminder module on a 2003 Land Rover Discovery? My Service Engine Soon light is on and I understand I may be able to simply reset this by inserting a pin in the module. I have looked behind the kick panel on the passenger side and under passenger seat and cannot find. Any help you can provide is appreciated.
If you read the reply I sent you from your PM you should now know you don't have a module and you do need to go get your codes read cause your engine or tranny is having a problem,
Biene Auguste
When the "Service Engine" light comes on in the dash, most of us just want to know how to make it go out. Yet that light is a source of help.
Real simple, if the light comes on either the engine or tranny are having a problem and you can't wish it away. You have to get the codes read, fix the problem and then have someone with a scanner clear the codes.
Paul p
