She has a problem taking fuel... help
C
crazdogg
I have a 97 LR Discovery 1, which 80% of the time won't take more than $5.00 of gas. She can be @ half a tank, 3/4 tank same problem. I want to be able to full my tank like normal folks.
thanks
Vent line may be clogged? have you had the tank replaced under the recall yet?
I would say vent line is either kinked or clogged.
C
crazdogg
dealer said my truck was'nt recalled.... but where can i the info on recall?
thanks .... will check vent line.
Moose
Are you filling by hand (i.e., actually holding the lever yourself) or locking the lever? Sometimes I have a hard time using the lever "lock" and have to slow the flow....it was a vent issue that the recall fixed.
C
crazdogg
by lever or hand once she acts up it does'nt matter. Either way I go slow, lowest on lever.
N
NHESS81
Hey, I have a 1997 D1 SE, and this has happened to me once in the last six weeks of owning it...my problem was that the pump kept trying its auto-shutoff even though the tank was not full, and it would seep gasoline out the top where the nozzle enters the tank..not much but still seeping enough. So I tried to do it manually, so the auto-shutoff would not interfere, and the pump just kept pushing gasoline out of the tank filler. So I drove around to the pump on the otherside, and voila, problem solved. I dont know what was up, whether my tank was being angry at me, or if the pump I was using was bad. It was almost like a huge backpressure in the fuel tank was forcing the pump to think it was full and forcing gasoline out, but it is wierd that the pump on the other side worked fine...........
Long story short, try a different pump or even station, who knows, maybe your stations pumps are hating you right now. It is worth a shot, if not, then you should let your dealer know it really does not matter if your VIN is part of the recall, but your tank is defective, and I am sure Land Rover would like to avoid a nice lawsuit down the road
This issue is normally a vent line that is clogged....
Johnathon65846
