Smoke!!!
D
DiscoDriver
I just replaced both upstream O2 sensors on my DII, initally because of a P0150 code indicating a bad Bank B senor. No more problems there, but within 20 miles I got a P0130 code indicating a possibly malfunctioning Bank A senosr. Luckily I bought two sensors so I immediately replaced the upstream Bank A sensor. Now, 800 miles later, the Bank A upstream is again throwing code P0130 which is most likely a bad sensor or bad connection. I opened the hood this AM to check it out and noticed wisps of white smoke rising up from near the upstream sensor/catalytic converter area.
I'm not loosing coolant, and there was no coolant or oil smell. I'm wonder if I may have a leaking transmission cooler line and this is what's "smoking", and perhaps mucking with a brand new O2 sensor?
Thanks,
Mark
If it has any oil or fluid (other than just water) leaking on to the O2 sensor, this can cause it to go bad... But if you not getting a smell, check to make sure the drain lines for the A/C unit are clear and not causing the whitle smoke... One on each side of the transmission, looks like a small black ****** connected to a tube... if they are clogging, be careful it will get you covered in some nasty stuff.
D
DiscoDriver
Thanks Joey. I "thought" I didn't have a coolant leak but it turns out I do; from the head gasket right above the Bank A sensor! So it looks like time to prepare for replacing the head gaskets!!!
SulliMtn
