Speaking of Premium Gas...
Slam
I saw the dreaded "check engine" light come on the other day. I let my tank run empty, and then I filled it with premium gas. I usually am cheap and just fill it with regular, but I thought if my rover was hurting, it could use the premium stuff. Anyway, the second I started up, the check engine light went off. I think I will probably run premium from now on.:smile:
I was the Lucas gods letting you know you were being a bad bad, Rover owner.
Slam
Yes, in fact, I heard someone scold me from the heavens.
Moose
Probably a bad wiring connection. Your assignment for the weekend is to trace every wire and connection, verify voltage, and verify proper connection. Report to us Monday with the results. :biggrin:
tmiller1
At least there aren't that many wires that you will have to check... :proud:
Heem
"Your assignment for the weekend is to trace every wire and connection"
Quiet! I have to do that on my Jeep this weekend. I keep blowing a fuse every time it starts up - but if i replace the fuse while it's running the fuse stays on. Grumble.
I think it's a chemical reaction that occurs when the driveway contains an AMC Jeep CJ, A Chrysler Jeep Wrangler, and a Land Rover Disco.
rrjmck
